Fifty150 Posted December 23, 2018 Share Posted December 23, 2018 Every good car forum needs this thread. Which oil & filter do you like? Why? Did you find a good deal on oil & filter, and want to share it? Do you have used oil analysis to post? Share your oil & filter experiences, good & bad. Steer others towards something better. Steer others away from something bad. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 23, 2018 Author Share Posted December 23, 2018 http://pqiadata.org/Milesyn_SXR_5W20.html Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 23, 2018 Author Share Posted December 23, 2018 https://pqiablog.com/2018/10/09/pqia-takes-a-look-at-amazonbasics-motor-oil-and-three-more-brands/ Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 23, 2018 Author Share Posted December 23, 2018 Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted December 23, 2018 Author Share Posted December 23, 2018 (edited) And here is something you don't want. PQIA Issues Two More Consumer Alerts on Motor Oil and Transmission Fluid on Retail Shelves in Ohio by PETROLEUM QUALITY INSTITUTE OF AMERICA • DECEMBER 17, 2018 The PQIA finds more motor oil and transmission fluid on retail store shelves in the state of Ohio that can cause harm to nearly all cars currently on the road, and catastrophic destruction of some turbo charged and/or gasoline direct-injection (T/GDI) engines. The products, Q Motor Oil and ATF, do not meet any known specifications, lack any meaningful level of additives necessary to protect an engine, and the manufacturer fails to comply with labeling regulations. The PQIA is in the process of reaching out to the auditors in each of the 88 counties in Ohio to alert them about the Q Motor Oil and ATF products examined, and others of concern that PQIA has found in the state of Ohio. But until action is taken, consumers are advised not to buy Q Motor Oil and ATF. DON’T BUY Click for Details PQIA recently visited retail stores in the Toledo Metropolitan area of Ohio and what we found, unfortunately, is more of what we observe in other locations in the state. That is, motor oils and transmission fluids that more than likely will cause equipment harm to virtually any car currently on the road. In addition, the product labels do not comply with labeling regulations. What PQIA found in the city of Oregon, located in northwestern Ohio in the Toledo Metropolitan area, and the largest suburb in Lucas County, is an abundance of the Q Motor Oil brand on the shelves in retail stores. This product has been examined by PQIA on several occasions, and the test results on the most recent samples, like with earlier samples of the product, show a motor oil that lacks the additives necessary to protect an engine from wear and keep it clean, and it contains metals typically associated with used oil. Further, the labels on the product do not comply with the Uniform Packaging and Labeling Regulations of the Fair Packaging and Labeling Act, and the Regulation for the Method of Sale of Commodities specified in National Institute of Standards and Technology (NIST) Handbook 130. The labels do not comply with these regulations because they fail to: Display a Declaration of Responsibility that states the name and address of the manufacturer, packer, or distributor. Display the viscosity grade classification preceded by the letters “SAE” in accordance with SAE International’s latest version of SAE J300, “Engine Oil Viscosity Classification.” Display, as defined by the latest version of SAE J183: “Engine Oil Performance and Engine Service Classification,” American Petroleum Institute (API) Publication 1509: “Engine Oil Licensing and Certification System,” European Automobile Manufacturers Association (ACEA): “European Oil Sequences,” or other Vehicle or Engine Manufacturer standards as approved in NIST Handbook 130: Section 2.33.1.3.1. Vehicle or Engine Manufacturer Standard. (Added 2014) Identify the specific vehicle or engine manufacturer standard, or standards, met in letters not less than 3.18 mm (1/8 in) in height. If the vehicle (motor) oil only meets a vehicle or engine manufacturer standard, the label must clearly identify that the oil is only intended for use where specifically recommended by the vehicle or engine manufacturer. (Added 2014) Provide a cautionary statement in compliance with the latest version of SAE J183, Appendix A, whenever the vehicle engine (motor) oil in the container or in bulk does not meet an active API service category as defined by the latest version of SAE J183, “Engine Oil Performance and Engine Service Classification (Other than “Energy Conserving”).” DON’T BUY Click for Details In addition to serious issues with the Q Motor Oil, results of the tests conducted on the Q Automatic Transmission “OIL” also reveal serious deficiencies that would likely result in harm to nearly all automotive transmissions currently on the road. So, one has to ask, how can a motor oil and ATF that clearly can cause harm to a car, with labels that don’t comply with regulations, continue to populate retail shelves in the state of Ohio? The PQIA has reached out to the Ohio Department of Agriculture – Division of Weights and Measures on several occasions for answers and to advise them about issues in the state, but, to date, there has been no response. In the absence of a response from the state, PQIA did some research and found that unlike states where the activities of the Division of Weights and Measures are administered and enforced by a central office, in Ohio the Department of Agriculture is the custodian of the primary standards of Weights and Measures and its Division of Weights and Measures works with county and city weights and measures auditors to enforce all Ohio laws relating to weights and measures. The auditors in Ohio’s 88 Counties serve as the Sealer of Weights and Measures for each county and according to Section 319.55 of the Ohio Revised Code, “The Auditor shall see that all state laws relating to weights and measures are strictly enforced throughout his county, and shall assist generally in the prosecution of all violations of such laws.” The PQIA is in the process of reaching out to the auditors in each of the 88 counties in Ohio to alert them about the Q Motor Oil and ATF products examined, and others of concern that PQIA has found in the state. We will keep readers apprised of the responses received and actions taken. The location and date of other “DON’T BUY” and “CONSUMER ALERT” products PQIA examined from retail shelves in Ohio over the past two years Include: Cleveland, OH, September 15, 2017Q 10•30 Motor OilMileage 365 Lubricants 5-30 Columbus, OH, December 3,2017Petrola Motor Oil Premium 5-30 Motor Oil SpecialPetrola Premium ATF Automatic Transmission Fluid Special North Lima, OH, April 25, 2018Mileage 365 Lubricants 5-30Mileage 365 Lubricants 10-30Mileage 365 Lubricants 10-40Q 10•30 Motor OilQ Automatic Transmission OilMileage 365 Lubricants ATF North Lima, OH, April 19, 2017Q 5•30 Motor OilQ 10•40 Motor OilQ 10•30 Motor Oil Warren, OH, April 25,2018Bullseye Automotive Products High Mileage Automatic Transmission Fluid ATF-A Edited December 23, 2018 by Fifty150 Quote Link to comment Share on other sites More sharing options...
