How to check glow plugs without multimeter
kyle4679
What are the cold start issues you are having?
Do you have a 12 volt test light? if you do then if you separate the glow plugs and hook the test light to the positive battery post if the light lights when you touch the glow plug  terminal then there is continuity .  It won't tell you if the glow plug is shorted.
