Bcm problems
Yes, most likely.
If you have the VIN of the donor vehicle you can check the version of firmware it has and compare it to your vehicle. If both are the same it should be possible to use Forscan to configure the new BCM to match yours. This is not a straightforward process or project but a determined person may get it to work.
Only a dealer can update firmware.
It is definitely easier to pay a dealer to do this, but some of us are thrifty and enjoy challenges.
