Fifty150 Posted July 6, 2018 Share Posted July 6, 2018 In the event that anyone is interested in acquiring one of these, and you don't see enough pics online, I am attaching photos. Through one of my contacts, I got a generic labeled item from the same factory which produces the same exact jack for known name brands. From my initial inspection, this item appears as if it is every bit capable of lifting the Transit Connect. With the knowledge that no matter which brand you buy, they all come from the same factory, you can make a wiser decision based upon pricing, availability, product support, and seller's warranty. As with all bottle jacks, you can own it forever if you inspect it for leaks and replace seals as needed, keep it clean and lubricate all moving parts, change hydraulic fluid as needed, purge excess air from hydraulic system, and keep the fluid level topped off. Quote Link to comment Share on other sites More sharing options...
Fifty150 Posted July 6, 2018 Author Share Posted July 6, 2018 Sam exact tool labeled for brand name seller: 2T Double Ram Bottle Jack Item# TF0202 Description 1. Dual-stage, steel hardened rams allow for longer travel. Lower retracted heights and higher extended heights. Heat treated saddle provides generous lifting area and secure grip. 2. A wide, rugged base provides stability and strength . Safety bypass valves prevent overloading. Specification Capacity: 4,000 lbs Lifting range: 5-7/8" to 14-9/16" Quote Link to comment Share on other sites More sharing options...
