kamjoe Posted April 10, 2018 Share Posted April 10, 2018 I have managed to change my break pads but the light still on , on the dash board .please help me reset the light out Quote Link to comment Share on other sites More sharing options...
BSUPC Posted April 12, 2018 Share Posted April 12, 2018 First I would start with the cheap and easy fix by checking to make sure you have enough brake fluid. Then I would hook up an code reader and see what the code is that is being tripped if the fluid is good. Also I assume you bled the brakes after the brake job. Quote Link to comment Share on other sites More sharing options...
