davidtheplumber Posted January 5, 2018 Share Posted January 5, 2018 Hi, Only just joined forum, have searched topics but cannot find answer. Is it possible to disconnect the remote key sensor in the van on my 2011 connect, but still have the central locking working. i.e need to put key in lock to open doors. I am not sure where this is located. Hope someone can help. The reason is for security as I believe on some occasions in a car park key scanning has taken place when I try to remote lock the door it opens again (certain it is not a fault). Thanks david. Quote Link to comment Share on other sites More sharing options...
BSUPC Posted January 5, 2018 Share Posted January 5, 2018 I do not know how to disable this. But from my experience with my 2012 TC the key fob works at a longer distance when facing the front of the TC and any angles to the sides or rear diminishes the range of the key fob. So just based off my experience I would suspect that the receiver for this feature would be in the front of the TC some where. Again this is just a guess on my part. Hopefully one of the member here can help narrow this down for you. Quote Link to comment Share on other sites More sharing options...
davidtheplumber Posted January 6, 2018 Author Share Posted January 6, 2018 Hi BSUPC, Thanks for the reply, I have had a good search underneath the dashboard, in the past there has been a raised dome shape on top near the windscreen.I guess the easiest option is to ask a Ford main dealer. Thanks David. BSUPC 1 Quote Link to comment Share on other sites More sharing options...
