connect throttle
rsm227
Hi
i was going along nicely stopped at some traffic lights,  as i went to move off no acceleration ??? so there is no response from the acc pedal.
any one had the same trouble, i know it is electronic had a test meter on it and came back with an open circuit so would it be a component that has given up ?
any advice is most welcome
thanks
Bob
Yeah so i gather,  so decided to take it off and have a look.  Turns out the central pivot of the pedal is plastic and it had snapped off where it goes into the electronic part of the pedal.
So i drilled a hole all the way through the spindle and inserted a small drill bit with super glue through it reassembled and left it to dry over night.
Have just refitted it to the van and now its as good as new,  simple job to do and cost nothing but small amount of time.
Thought i would put it on here so if any one else has this problem then there is a simple solution available to them.
Bob.
