Josef Posted October 10, 2017 Share Posted October 10, 2017 Whenever I start my Ford Tourneo Connect 1.8 TDCI 2004, the glow plug indication light at the gauges, lights up for 2 seconds and turns off. Clearly it is not a sufficient time period for the plugs to heat up in cold weather hence, the starting is difficult. Do you have any idea why is that?What part sets the heating time? Is it the relay? is there a timer somewhere ? Is it managed by the ECU? Could the plugs be faulted (although I have replaced them 2 years ago)? Thank you in advance Josef Quote Link to comment Share on other sites More sharing options...
mrtn Posted October 10, 2017 Share Posted October 10, 2017 There's a timer based on the outside temperature. Don't know if it's ECU driven or standalone. Glow plug condition has no effect on the timer duration. Always goes full time as needed even if all plugs are bad. Quote Link to comment Share on other sites More sharing options...
Josef Posted October 11, 2017 Author Share Posted October 11, 2017 Thanks for your reply. Do you have any idea where is this timer located? I would like to check it or try to replace it. Quote Link to comment Share on other sites More sharing options...
mrtn Posted October 11, 2017 Share Posted October 11, 2017 Don't know. There's a relay in the fuse box most likely. Might want to check that. Quote Link to comment Share on other sites More sharing options...
