foes Posted January 21, 2011 Share Posted January 21, 2011 Does anybody know of a side mount roll up patio awning that will fit the Transit? Quote Link to comment Share on other sites More sharing options...
FTCPNW Posted January 21, 2011 Share Posted January 21, 2011 http://www.rackattack.com/product-pages/thule-326-awning.asp On 1/21/2011 at 4:47 AM, foes said: Does anybody know of a side mount roll up patio awning that will fit the Transit? Quote Link to comment Share on other sites More sharing options...
foes Posted January 22, 2011 Author Share Posted January 22, 2011 Thanks for the lead but it is overpriced and my first choice would be to mount directly to the body just above the sliding door and not on a roof rack. anybody got ideas? Quote Link to comment Share on other sites More sharing options...
Bikesnbreakdowns Posted January 30, 2012 Share Posted January 30, 2012 (edited) The ARB awning is a lot cheaper, still requires a roof rack though http://store.arbusa.com/Search.aspx?k=awning Edited January 30, 2012 by Bikesnbreakdowns Quote Link to comment Share on other sites More sharing options...
SteveMalone189 Posted June 17, 2017 Share Posted June 17, 2017 It is possible to mount an ARB awning on a TC without attaching it to a roof rack. We did so on our TC and posted the details on the Unofficial Camp Inn Forum: http://campinnforum.com/community/threads/arb-tow-vehicle-awning.3901/ The thread includes details of how to fabricate some inexpensive wind walls for use with the awning (to block low angle sun as well as wind), plus it links to an account where our custom mount survived ripping a low hanging power line off a building last fall in Baja California Sur, Mexico. Quote Link to comment Share on other sites More sharing options...
r1alvin Posted June 18, 2017 Share Posted June 18, 2017 (edited) On 6/17/2017 at 9:09 PM, SteveMalone189 said: It is possible to mount an ARB awning on a TC without attaching it to a roof rack. We did so on our TC and posted the details on the Unofficial Camp Inn Forum: http://campinnforum.com/community/threads/arb-tow-vehicle-awning.3901/ The thread includes details of how to fabricate some inexpensive wind walls for use with the awning (to block low angle sun as well as wind), plus it links to an account where our custom mount survived ripping a low hanging power line off a building last fall in Baja California Sur, Mexico. Expand I was wondering whats underneath those plastic caps on the roof. Can you please elaborate more on that? No drilling required? So all it is is a hole that goes from the roof to the interior? I'm guessing that when you said you used sS lag bolts, and judging by the picture, you screwed them from the inside of the van through the hole into the wood above,,,, Edited June 18, 2017 by r1alvin Quote Link to comment Share on other sites More sharing options...
thx138 Posted June 18, 2017 Share Posted June 18, 2017 I miss my awning, I need to get one for my van. One of the best things I did to mine was adding led lights to it. Quote Link to comment Share on other sites More sharing options...
SteveMalone189 Posted June 18, 2017 Share Posted June 18, 2017 No drilling required. The plastic caps (which are in the gutter where factory roof rack rails can be installed) cover elongated holes in the roof's sheet metal. These are the points where the factory rails would be installed. From the inside, you can squeeze the sides of the part that protrudes through to the interior and then push up to pop them out. On the exterior side, the bottom of the cap has a neoprene-like gasket that seals out the weather. You will need to remove some of the sound insulating foam on the side door track in order to access these holes in the midsection of the van (those in the rear can clearly be seen in a cargo van configuration). The foam is held in place by plastic "bolts" that have a wide, thin cap and a one inch or so barbed bolt. They press in place to hold the foam in position. In theory you might be able to back these out with a screwdriver, but there are auto trim pry bars made for this purpose. We live on the road, so I picked one up at a NAPA parts store in Texas. Yes, I did screw lag bolts into the bottom of the 2x2 to secure the same to the roof. The install took place last October. If I had access to better tools I likely would have bolted the 2x2 to the roof, but it is unnecessary, as proven by the power line that we snagged in Mexico. The way it is currently installed, that rack isn't going anywhere. Quote Link to comment Share on other sites More sharing options...
