Jamiec90 Posted January 28, 2016 Share Posted January 28, 2016 Hi in desperate need of some help guys my heating just randomly stopped working I have changed the thermostat , heater matrix and egr cooler engine gets hot and temperature gauge sits right , now I have a little bit of heat but very little and intermittent it comes and goes and only comes out of the passenger side vents the drivers sides are constantly cold PLEASE HELP cheers Quote Link to comment Share on other sites More sharing options...
mrtn Posted January 28, 2016 Share Posted January 28, 2016 So there actually is heat but only on one side? Then there's something wrong with the flaps that direct air flow. Quote Link to comment Share on other sites More sharing options...
Jamiec90 Posted January 29, 2016 Author Share Posted January 29, 2016 There is heat but it's only luke warm and goes from warm to cold it never actually gets hot , the drivers side vents do work and blow out air it's just cold Thanks Quote Link to comment Share on other sites More sharing options...
mrtn Posted January 29, 2016 Share Posted January 29, 2016 Is there resistance in the direction dial when you turn it? Remove the console plate and check the connections in the back. Quote Link to comment Share on other sites More sharing options...
