Paul Hauser Posted January 4, 2016 Share Posted January 4, 2016 I have a project that requires a wire run to the overhead shelf. does anyone have tips or tricks (or pics or vids) to remove the trim from the A pillar and the dash? Quote Link to comment Share on other sites More sharing options...
DonShockley Posted January 4, 2016 Share Posted January 4, 2016 (edited) Here's the thread I made documenting how I ran power to add USB ports in the overhead shelf. http://fordtransitconnectforum.com/topic/3936-added-usb-power-to-overhead-shelf/#entry11306 In the closeup photo at the base of the trim you can see the blue anchor pin and the black slot that it goes into which is how the trim is held in place. The trim piece will just pull off with gentle pulling. To get down into the dash I just pried the existing gap open slightly to feed the wires through. Edited January 4, 2016 by DonShockley Quote Link to comment Share on other sites More sharing options...
Paul Hauser Posted January 4, 2016 Author Share Posted January 4, 2016 What's the yellow thing near the top? It looks a little scary. Is there any danger of deploying the airbag? Quote Link to comment Share on other sites More sharing options...
DonShockley Posted January 4, 2016 Share Posted January 4, 2016 It's just another clip, like the blue ones, but has an extra tether. I think it's purpose is to keep the trim from flying too far if the air bag deploys. There's a little T-slot in the trim it slips into. I think it was just chance which section happened to come loose first, the clip/frame connection or the clip/trim connection. I didn't worry too much about air bag deployment since it appeared the electrical connections were further up and to the rear in the headliner from where I was working. That connection at the bottom is just a strap to anchor the bottom. Quote Link to comment Share on other sites More sharing options...
