nially Posted October 18, 2010 Share Posted October 18, 2010 hi, does anyone have any good suggestions on how to boost preformance from the engine? anything simple and easy that can be done? cheers Quote Link to comment Share on other sites More sharing options...
ncranchero Posted October 21, 2010 Share Posted October 21, 2010 I've been praying but so far no luck !! :D Quote Link to comment Share on other sites More sharing options...
WhiteVanManUSA Posted December 12, 2010 Share Posted December 12, 2010 On 10/18/2010 at 1:50 PM, nially said: hi, does anyone have any good suggestions on how to boost preformance from the engine? anything simple and easy that can be done? cheers Try installing a K& N Filter they come with a million mile Guarantee and need maintaining every 50K miles which is basically a soak in a cleaner rinse off with a hose and then allow to dry before re-oiling the filter before re installation . I recommend you keep your OE filter somewhere safe so when you are doing the clean and re-oil of the filter you can install the OE filter and still use your vehicle. See link below for all Filters . Make sure you order the Recharger kit to service the filter as you need to use the special cleaner and oil . Happy transitting Quote Link to comment Share on other sites More sharing options...
MattCook Posted March 14, 2011 Share Posted March 14, 2011 On 12/12/2010 at 3:45 AM, WhiteVanManUSA said: Try installing a K& N Filter they come with a million mile Guarantee and need maintaining every 50K miles which is basically a soak in a cleaner rinse off with a hose and then allow to dry before re-oiling the filter before re installation . I recommend you keep your OE filter somewhere safe so when you are doing the clean and re-oil of the filter you can install the OE filter and still use your vehicle. See link below for all Filters . Make sure you order the Recharger kit to service the filter as you need to use the special cleaner and oil . Happy transitting DO NOT install K&N filters in a TC, the oil gets on the sensors and then you will have to replace the sensors in the airbox. These only work on vehicles with the mass air flow sensor located elsewhere. Quote Link to comment Share on other sites More sharing options...
Flying Media Posted March 16, 2011 Share Posted March 16, 2011 (edited) On 3/14/2011 at 8:48 AM, MattCook said: DO NOT install K&N filters in a TC, the oil gets on the sensors and then you will have to replace the sensors in the airbox. These only work on vehicles with the mass air flow sensor located elsewhere. OH please i have had my k&n in for the last 12000 miles only a fool over oils the filter Edited March 16, 2011 by Flying Media Quote Link to comment Share on other sites More sharing options...
ncranchero Posted March 16, 2011 Share Posted March 16, 2011 Guess there's a lot of fools out there. Oil contaminated MAF's are common topics on all Ford forums. How much neck snapping performance did you get out of that K&N anyway? K&N's, CAI's that hang in the open in HOT engine compartments .......... :finger: IMO. Quote Link to comment Share on other sites More sharing options...
Flying Media Posted March 17, 2011 Share Posted March 17, 2011 On 3/16/2011 at 11:55 PM, ncranchero said: Guess there's a lot of fools out there. Oil contaminated MAF's are common topics on all Ford forums. How much neck snapping performance did you get out of that K&N anyway? K&N's, CAI's that hang in the open in HOT engine compartments .......... :finger: IMO. must be was not looking for neck snapping performance just trying to save the land fills... just like the oil filter i put on reuseable http://www.kandpengineering.com/S15.shtml Quote Link to comment Share on other sites More sharing options...
ncranchero Posted March 17, 2011 Share Posted March 17, 2011 I'm certainly not opposed to saving landfills/earth but K&N's aren't going to do it. Recommended air filter change interval is 30K miles and even with the mileage I drive that won't be twice a year! If you're doing it for performance .................... you have the wrong vehicle! :rolleyes: IMO. Quote Link to comment Share on other sites More sharing options...
