westshore Posted February 27, 2015 Share Posted February 27, 2015 2012 USA TC, getting a rattle over the top rear of left sliding door while traveling on rough road. Almost sounds like a loose nut or bolt as it sometimes occurs when starting out or changing course. Anyone experience this/have a solution? I had opportunity to ride in a 2013 model and it had the same rattle! I am considering pulling the headliner to have a better look. Quote Link to comment Share on other sites More sharing options...
johnsonmy Posted March 3, 2015 Share Posted March 3, 2015 I have a rattle in that general area in my 2011, but haven't researched its actual location. Assumed it was the door itself. Quote Link to comment Share on other sites More sharing options...
kndlkstms Posted November 7, 2015 Share Posted November 7, 2015 Our 2012 has that noise too . Sounds like a loose wiring harness or some "wrapped" or other "soft" item banging around .Upper door , roof area , B pillar ? I wonder if there's a TSB about that . We get an wind noise from the roof rack above 45 mph that need fixing , and then the rattle. Fords TSB program is pretty good with these kinds of problems , but the customer has to make a "stink" to get them resolved . Quote Link to comment Share on other sites More sharing options...
103west43rd Posted November 8, 2015 Share Posted November 8, 2015 Hello westshore. As per the 2010 Transit Connect wiring diagram, there is a wiring run above both side doors. If you have the DeWalt Tool Link option, the antennas are also above both side doors. Quote Link to comment Share on other sites More sharing options...
