jv2937 Posted June 18, 2014 Share Posted June 18, 2014 My 2010 Ford transit connect the headlights stay on when you exit the car if you disconnect the battery then read connect the battery goes back to normal now disconnected battery headlights Stay on after you connect the battery back up. Anyone out there having problems with their headlights staying on. Quote Link to comment Share on other sites More sharing options...
mrtn Posted June 18, 2014 Share Posted June 18, 2014 How long would they stay on? Have an aux alarm with followmehome lights enabled? Quote Link to comment Share on other sites More sharing options...
103west43rd Posted June 18, 2014 Share Posted June 18, 2014 Hello jv2937. There are multiple reasons for headlamps to stay on after the vehicle is shut off. it could be the low beam relay, the DRL (daytime running lights) relay, the headlamp switch, the GEM (generic electronic module) or wiring. Without running multiple tests, it would be only a guess to what is causing your issue. Quote Link to comment Share on other sites More sharing options...
