Cosmin Crisan Posted December 31, 2013 Share Posted December 31, 2013 (edited) Hi there guys! First, I want to thank you for the wealth of info that you share, it helps a lot. Now, my dilemma: I have a 2013 TC XL cargo van and I want new speakers for the front. Crutchfield says 5 1/4 and amazon gives me 6.5 (not that i mind, the ones that I want are 6.5, Infinity reference 6030cs). I could return them, but maybe you can help. Anyone know for sure? could I fit 6.5 if I wanted (would I have to cut, speakers off center, etc?) Thanks in advance. Edited December 31, 2013 by Cosmin Crisan Quote Link to comment Share on other sites More sharing options...
mrtn Posted December 31, 2013 Share Posted December 31, 2013 You would have to cut the sheet metal. The speakers are already off center in OEM locations so you'll be off even more. Bigger speakers make a big difference in TC doors. I reverted to OEM size from 5x7 and have regretted since, even with an amp it loses the punch, it just comes down to physics.The only thing you have to check if the magnet fits. Make sure you insulate the doors while you have them opened up. Again, big difference. Now: get an amp (speaker level inputs, 2 channels) Quote Link to comment Share on other sites More sharing options...
Cosmin Crisan Posted December 31, 2013 Author Share Posted December 31, 2013 I was thinking, could you surface mount some 6.5 speakers? cut the door cover panel to size and use the grills that are provided? I will have to do that for the tweeters anyway. Quote Link to comment Share on other sites More sharing options...
Cosmin Crisan Posted January 10, 2014 Author Share Posted January 10, 2014 For all those interested, the speakers are 100% 5 1/4", no matter what Amazon says. I got some 6.5 components and dynamat and will attempt the install soon. Also, the stereo comes out via some screws and bolts, no special removal keys needed. Will keep you posted. Quote Link to comment Share on other sites More sharing options...
