Precisionair Posted February 6, 2013 Share Posted February 6, 2013 Built this break away carrier to haul big ticket items such as condensers, and evaporators, up to 250 lbs. It is adjustable up to 36" in length, and has tie-down holes on the bottom of each cross-bar for ratchet tie-down points. It stores inside the TC, in a box with felt bumpers. (No rattles)... Also in the box are the components for a hitch mounted break-away work bench.(not pictured) Quote Link to comment Share on other sites More sharing options...
ActiveIndy Posted February 7, 2013 Share Posted February 7, 2013 Nicely done! It would appear getting the load perfectly balanced is critical? Quote Link to comment Share on other sites More sharing options...
Precisionair Posted February 7, 2013 Author Share Posted February 7, 2013 Thanks! .... Not really critical, but if the item has most of its mass off to one side, just rotate till the heavy side is closest to receiver hitchs' centerline.... Quote Link to comment Share on other sites More sharing options...
