Ignition switched fuse on 2021 Transit Connect
Posted (edited)
Hi folks,
In the course of a hardwired dashcam installation on my cargo XL, I needed to find a fuse that was ignition-switched in the passenger compartment fuse box (behind the glove compartment). I tested a few and here's what I chose:
- The ignition-switched fuse I tapped was #3, "parking assist control module".
- For constant power, I chose #23, "audio unit".
Hope this helps someone! I believe it may also apply to 2019, 2020, 2022, and 2023 models at least.
Edited by cjdaniel
adding other years for searchability
