cjdaniel Posted May 23, 2025 Share Posted May 23, 2025 (edited) Hi folks, In the course of a hardwired dashcam installation on my cargo XL, I needed to find a fuse that was ignition-switched in the passenger compartment fuse box (behind the glove compartment). I tested a few and here's what I chose: - The ignition-switched fuse I tapped was #3, "parking assist control module". - For constant power, I chose #23, "audio unit". Hope this helps someone! I believe it may also apply to 2019, 2020, 2022, and 2023 models at least. Edited May 23, 2025 by cjdaniel adding other years for searchability windguy 1 Quote Link to comment Share on other sites More sharing options...
windguy Posted May 25, 2025 Share Posted May 25, 2025 Thanks for sharing. What model dashcam did you install and where is it mounted? Quote Link to comment Share on other sites More sharing options...
