JayZ Posted April 15 Share Posted April 15 I have a 2020 Ford Transit Connect XLT Cargo LWB without automatic climate control. I saw that there appears to be an automatic climate control unit that looks like it’s just an easy swap. Does anyone know if it will work to just swap the control units, or is it a more complex process? specifically thinking this part: https://www.ebay.com/itm/395395766868?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=e1a6yNg_Td-&sssrc=4429486&ssuid=gbofG3JTTr2&var=&widget_ver=artemis&media=COPY Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted April 26 Share Posted April 26 (edited) You can't simply swap parts ( I think). The automatic controls are networked and there are programming or configuration changes that need to be made. Here is a forum thread about someone upgrading their climate control in a Ford Superduty. The OP used Forscan to make all changes. Forscan may have an easy way to change the configuration to recognize the new module but you won't know this until you run Forscan connected to your van. Need help programming HVAC module - Ford Truck Enthusiasts Forums You also will need to install some temperature and humidity sensors for the new module. Edited April 26 by Don Ridley Quote Link to comment Share on other sites More sharing options...
