Power Steering Issue
Hi, my 2016 connect has developed a strange issue with the power steering. When I start the engine and drive off I have no power steering for perhaps 20 or 30 seconds, the power steering then kicks in and everything is fine, nothing shows on the dashboard. However, if I start the engine, immediately select reverse, then select 1st, I can drive away without any power steering issues. If I do forget and drive off in 1st (no power steering) if I stop, select reverse then immediately select first, the power steering issue is cleared.
Has anyone experienced this issue? Does anyone have any idea what the problem/resolution is?
