Ā  Ā
2016 ford transit connect 1560 TDCI - ALL brakes binding and will not release = HELP !!
Hello fellow Ford transit connect owners šŸ˜‰
Ā
Please advise me on this: ALL brake discs started to bind and get hot. When I pulled up to a junction - braked - went to pull forward ALL discs were brake locked for 15 seconds, when they did release still binding ??.
Ā
I think it's the ABS / Hill assist valve failing to release and binding ???. Ā Local garage think Master cylinder / Servo, having checked today... without ANY power on (engine not running and electrics OFF so NO servo assistance) van can be pushed freely...then as soon as brakeĀ pedal is pushed it locks all discs again for 20 seconds ???
Ā
IF it were master cylinder it would be either front or rear discs locking ... NOT all... Servo pressureĀ isn't active without engine running???.
Ā
PLEASE help what couldĀ it be ???. Van has only 48000 miles, very well maintained and faultless until now :-(. Thanks in advance šŸ™‚
Ā  Ā
  • 7 months later...
Ā
Ā
Ā
Ā
We had the same problem. It was the HCU or hydraulic control unit. The dealer struggled but got it on the third try after pads and rotors a caliper and me pissed off at the shade tree way they ā€œdiagnosedā€ it.Ā
