Vansty Connect Posted November 14, 2024 Share Posted November 14, 2024 Hello fellow Ford transit connect owners 😉 Please advise me on this: ALL brake discs started to bind and get hot. When I pulled up to a junction - braked - went to pull forward ALL discs were brake locked for 15 seconds, when they did release still binding ??. I think it's the ABS / Hill assist valve failing to release and binding ???. Local garage think Master cylinder / Servo, having checked today... without ANY power on (engine not running and electrics OFF so NO servo assistance) van can be pushed freely...then as soon as brake pedal is pushed it locks all discs again for 20 seconds ??? IF it were master cylinder it would be either front or rear discs locking ... NOT all... Servo pressure isn't active without engine running???. PLEASE help what could it be ???. Van has only 48000 miles, very well maintained and faultless until now :-(. Thanks in advance 🙂 Quote Link to comment Share on other sites More sharing options...
G B L Posted November 15, 2024 Share Posted November 15, 2024 Sounds like the first thing is a good scan with Forscan or a good scantool. Pull The ABS Motor fuse and see if the lock up is stopped. Does it lock up if the brakes are used with the power off? keep us up dated, Thanks. Quote Link to comment Share on other sites More sharing options...
