Hard breaking wobble.
Vince
Hello,
My 2019 Ford transit connect van has a slight wobble during hard breaking.
I just had brand new Michelin tires installed and balanced.
I also had the brakes inspected at Les Schwab. They say everything looks good.
I'm wondering if it could be the caliper mounting bolts that have either bent or warped somehow.
Any feedback would be much appreciated.
Thank you.
Vince
The bolts are fine unless the brakes have been damaged by contact with something. This type of damage would also have damaged the wheel.
You are probably feeling a rotor that is warped or has uneven brake pad deposits. This problem plagues many disc brakes and happens for a variety of reasons. You need new pads and rotors to fix it. The brakes will stop OK and are safe to use but they are annoying in this condition.
