skippyelwell Posted April 4, 2023 Share Posted April 4, 2023 I've looking around for some info on valve adjustment for the 2.5L in my 2014 TC, so far I haven't found much. Specs for intake and exhaust, availability of shims, any special tools required? Thanks Quote Link to comment Share on other sites More sharing options...
G B L Posted April 6, 2023 Share Posted April 6, 2023 To measure the clearance is straight forward to adjust them requires the removal of the camshafts and that will require the cam timing to be involved. A formidable job and with a transverse engine . The 2.5 engine timing is a challenge as the crank sprocket does not have a key and relies on the clamping force of the balancer. If you measure them and they are not too tight I would stop there. Quote Link to comment Share on other sites More sharing options...
skippyelwell Posted April 6, 2023 Author Share Posted April 6, 2023 On 4/6/2023 at 1:30 AM, G B L said: To measure the clearance is straight forward to adjust them requires the removal of the camshafts and that will require the cam timing to be involved. A formidable job and with a transverse engine . The 2.5 engine timing is a challenge as the crank sprocket does not have a key and relies on the clamping force of the balancer. If you measure them and they are not too tight I would stop there. Expand Thanks for the advice, that brings me to my second question. Is there a replacement mileage stated as to when the timing chain components need to be changed out? Quote Link to comment Share on other sites More sharing options...
G B L Posted April 7, 2023 Share Posted April 7, 2023 There is no regular interval. The better job you do on keeping the Oil clean the longer the Cam phaser and chain guides will last. Some of the 2.5s have clocked large mileages over 300000mi. It pays to keep the oil clean. As a side note the transmissions will benefit from Drain and fills at 25000 to 30000 mile intervals. skippyelwell 1 Quote Link to comment Share on other sites More sharing options...
skippyelwell Posted April 9, 2023 Author Share Posted April 9, 2023 On 4/7/2023 at 1:39 PM, G B L said: There is no regular interval. The better job you do on keeping the Oil clean the longer the Cam phaser and chain guides will last. Some of the 2.5s have clocked large mileages over 300000mi. It pays to keep the oil clean. As a side note the transmissions will benefit from Drain and fills at 25000 to 30000 mile intervals. Expand Thanks again, just watched a video on re-timing the 2.5L ? Lots of opportunity to screw up. Quote Link to comment Share on other sites More sharing options...
G B L Posted April 9, 2023 Share Posted April 9, 2023 On 4/9/2023 at 1:09 PM, skippyelwell said: Lots of opportunity to screw up Expand Yes . the only reason to go in would be a very tight valve. Quote Link to comment Share on other sites More sharing options...
