Rodduz Posted March 2, 2023 Share Posted March 2, 2023 Hi, few strange things happened lately. First I left side lights on when got out of van and the battery drained dead in about 4 hours. The battery was on it's last legs anyway so I bought a new one. Fitted it... Van started, I drove off, after about 5 minutes the ABS and handbrake lights were coming on and it wanted to cut out all the time. Keeping revs high stopped it doing so. I got to my destination where I had to crack on with work. I thought I'd need a lift home but tried Van anyway. Started and cut out straight away once then started fine and ticked over, reversed out and drove fine for about 5 minutes again then started to do the same abs and hand brake light, and wanted to cut out. Got it home, going up my hill it seemed to be down on power at times and then the power kicked back and it flee up the hill like it usually does. Parallel parking and it cut out twice doing so, parked up and it's been sat her idling fine for approx 20 minutes. Any ideas? Cheers Quote Link to comment Share on other sites More sharing options...
mrtn Posted March 2, 2023 Share Posted March 2, 2023 Did you do the idle learn procedure? Quote Link to comment Share on other sites More sharing options...
Rodduz Posted March 3, 2023 Author Share Posted March 3, 2023 (edited) On 3/2/2023 at 9:02 PM, mrtn said: Did you do the idle learn procedure? Expand Nope, what is that please? It's a manual if that makes a difference? Edited March 3, 2023 by Rodduz Quote Link to comment Share on other sites More sharing options...
