2012 Connect: Passenger Door, Only Unlocks Manually From Inside.
The 2012 Connect I have, is Ex-Fleet (Cadent/National Grid).
As some sort of security/safety feature, the Passenger Door, has been set, so that it Only Unlocks/Opens, Manually From the Inside.
Is there anyway that I can change this, so that the passenger door, can be opended from the outside, after using the fob to unlock the central locking...
Seconded. My manual only lists lock settings that affect all doors or groups of doors: autolock/unlock, cargo protect/stepped unlocking, and sliding door memory lock/"rear door reverse". It's possible 2012 adds more granular settings, but I've also got a single door that doesn't remote-unlock sometimes, and it's because the actuator linkage inside gets jammed.
