EmoMorales Posted August 10, 2022 Share Posted August 10, 2022 Having issues with my ambient air sensor. It is getting crazy readings nowhere near actual outside air temperature. I’ve replaced the sensor twice. The first time I replaced it it worked fine for a few months. It started acting weird again so I replaced it again thinking maybe it was just a bad sensor. Again the second sensor worked for a few months, now it’s acting simple again. Is anyone had this issue? If so what did you do to fix it? Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted August 10, 2022 Share Posted August 10, 2022 The service manual says to reset the keep alive memory (KAM) whenever a sensor is replaced. Disconnect the negative cable on the battery for about 10 minutes to do a master reset of all modules and KAM. Quote Link to comment Share on other sites More sharing options...
EmoMorales Posted August 11, 2022 Author Share Posted August 11, 2022 I think it my be a bad connector. When I wiggle it after a few minutes the temperature will go back to normal. Quote Link to comment Share on other sites More sharing options...
