2016 Ford Transit Connect - Left Sliding Door Roller Replacement?
dgotc
At first I thought it was just dust in the roller tracks, but I think after the door slammed open on a hill the middle track is binding. It has a bit of play that binds it's movement at certain angles. Has anyone replaced these? I'm looking for tips or a procedure as well as where to get parts.
I did find this part: 2069951
https://www.ebay.com/itm/255416625860
Is this correct? Does anyone have a cheaper resource for this part or a better fix?
Thanks
Don to the rescue, again! Thanks.
In order to possibly avoid drilling the rivets out and having to re-rivet, I wonder if the "Sliding door hinge bolts" described in step 5 can be removed and that roller unit replaced with the door still in place. That is the failed part.
