LTB: 2013 (or compatible) TC various parts to add power door locks to sliding door and rear door
wb6vpm
I am looking for the following parts for my 2013 TC, as I'm looking to add power door locks to my van, and it doesn't appear that there is any good way to use an aftermarket solenoid:
  • Driver sliding door power door latch with pigtail (I believe the wiring pigtail is part of the lock latch assembly)
  • Passenger sliding door power door latch with pigtail (I believe the wiring pigtail is part of the lock latch assembly)
  • Both driver & passenger sliding door pin contacts (need both the pillar side and the door side, these are contacts at the pillar that allow electrical connectivity between the chassis and door for the door locks) with a wire pigtail of the pillar side connectors to splice into body harness (the door side connects to the aforementioned pigtail from the latch assembly)
  • Rear door power door latch
  • Rear door wiring harness (the door lock side, I do not have rear windows, so I don't need the wiper/heater wires, but not a big deal if they are there though)
  • Interested in, but will depend on price, the rear door trim panels. Would prefer the style that has the storage, but either the flat vinyl or even the XL style "wood" ones are acceptable (including mounting clips as necessary)
Thanks in advance everyone!
