MarkH Posted April 12, 2012 Share Posted April 12, 2012 I recently purchased a 2012 TC XLT Premium and according to the manual it has a ten minute accessory delay. I should be able to raise the power windows or play radio for ten minutes after the key is turned off. My TC does not allow this. Is this correct? Is the anual wrong? Can anyone raise their power windows after the key is turned to off? If my TC should be ding this I need to take it back for repair. Quote Link to comment Share on other sites More sharing options...
Tranzy Posted April 12, 2012 Share Posted April 12, 2012 I also have a 2012. The radio will stay on for 10 minutes, and the windows won't work, unless I turn the key. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Nyvideo Posted April 14, 2012 Share Posted April 14, 2012 I also have a 2012 XLT Premium. Once I shut the key my radio turns off and the windows don't operate. Quote Link to comment Share on other sites More sharing options...
Tranzy Posted April 15, 2012 Share Posted April 15, 2012 After you turn off the key, the windows will not work, but if you push the radio button, the radio will turn on for 10 minutes. Same said if you turn the key to accessory, the windows will not work, and the radio will. If you turn the key on all the way, without starting the vehicle, you have full power to the windows and the radio. Quote Link to comment Share on other sites More sharing options...
Nyvideo Posted April 16, 2012 Share Posted April 16, 2012 After I turn off my ignition, i push the radio button and it does turn on. When it goes through its startup, right after it says Ford Audio it says 1 hour. I assume that means it will stay on for 1 hr. I sat in my car waiting to pick someone up and I was over 20 min and it was still on. Quote Link to comment Share on other sites More sharing options...
MarkH Posted April 16, 2012 Author Share Posted April 16, 2012 I think I may be seeing a pattern here. I have the AM/FM Single CD player (Late Availability). Maybe only certain stereos will play after the key is turned to the off position. I asked my dealership to research this a few days ago and they haven't got back to me yet. Quote Link to comment Share on other sites More sharing options...
