eggman14 Posted August 31, 2021 Share Posted August 31, 2021 Hi all, Problem is as title suggests, lubed up all the linkages which helped a bit, popped off the connectors at the transmission end and movement is smooth. I read on a thread somewhere there is a bush on the selector which can get a bit chewed up. This morning removed my selector but there is no bush on the end of it? has it fallen inside the transmission? will it be an issue if i leave it in there? see pic below, part is 7335 at bottom of picture. thanks in advance Quote Link to comment Share on other sites More sharing options...
