djezrock Posted September 2, 2020 Share Posted September 2, 2020 I started having an issue while driving. Van is a 2012 Ford Transit connect XLT. The Ac would kick off and the blower fan would kick off then on. The traction control light would remain on and the mileage gauge would blank out an then come back. The computer would appear to reset itself and then all was acting normal again. Sometimes I would restart vehicle and it would be fine. Yesterday, it got worse. I will attach some videos if I can to show what happened. All the gauges and warning signs started going nuts. After pulling over, I turned vehicle off to restart and it was dead. Even with the key out, they was clicking coming from under the dash. I took to my mechanic and they could not pull any trouble codes and they disconnected the aftermarket remote start and alarm as they figured this would be the most likely cause of the problem. Today after getting to work, I went out to start and noticed my keyless entry was not working. Once i got inside, there was not power and just a constant clicking from under the steering wheel. I believe I isolated it to just behind the fuse box, there is another box with what appears to be 4 yellow tabs with wire clusters going into it. I will try to attach a photo as well so hopefully someone can identify what this control box is for. I take the Van in tomorrow to the mechanic again however they seem to think there is not much they can do unless they can get the problem to duplicate. Any help would be greatly appreciated. Dash short.MOV Quote Link to comment Share on other sites More sharing options...
djezrock Posted September 2, 2020 Author Share Posted September 2, 2020 Here is the clicking sound clicking short.MOV Quote Link to comment Share on other sites More sharing options...
djezrock Posted September 2, 2020 Author Share Posted September 2, 2020 Here is what I am trying to identify. It is behind the fuse box under the steering wheel. Has 4 yellow tabs Quote Link to comment Share on other sites More sharing options...
