Transit Audio Questions
I am installing a new head unit with a component speakers set and an amp in a 2012 TC this weekend and had a few questions. The speaker wires in the doors are a baby blue and white. I am assuming that white is positive and I think I read that some one tested that with a battery. Just wanted to see if anyone else could confirm that.
Second question. The stereo I am installing has the ability to connect to the steering wheel control unit. Does anyone know what wire that is on the factory harness? I have read mixed information. Some people say you will need an adapter, others say you can tap into a single wire. Has anyone done this?
If I can't figure it out, not a big deal. I will post install pics when I finish hopefully tomorrow.
Thanks!
Edited by 100PercentJuice
Thanks!
The wiring diagram for my 2010 shows white and gray speaker wires for the door speakers. The white is marked positive. The steering wheel control unit uses two wires on the 2010, white/black and brown/yellow. Hope that helps.
  • 8 months later...
Thanks!
and what happened to your install pictures???
Thanks!
Hi there,
I am in the exact same situation as you. Installed a Kenwood headunit last weekend in my 2007 transit connect and a pair of spekers.
I have the same colour speaker wires and have also used white as positive but I am not 100% sure this is correct, did you confirm this?? (you can buy a speaker adaptor lead so you do not need to cut the existing one but mine came wrong and I could't wait)
As for the steering wheel interface i used this adaptor , plus an extra lead specific to your head unit's make, works like a charm!
Any help on the speaker wire colours would be much appreciated (white and light blue at the speaker end)
Thanks!
Hi there,
