Switta Posted September 22, 2019 Share Posted September 22, 2019 Hello All my name is Dave i just purchased a nice low mileage 2012 connect and have been fixing all the small issues , but there is one that has me baffled ? i have come here to join this site in hopes someone has had this problem and i can figure it out with out going to the stealership so my high beams will not work ? the high beam indicator comes on and i hear the relay click to the left of the steering wheel in the fuse box area , i replaced the high beam relay under the hood in that fuse box and the bulbs check good with tester but no high beams ? i don't know what else to look for ? fuses are all good . Thanks to anyone for ideas that may help . Dave . Quote Link to comment Share on other sites More sharing options...
dinocarsfast Posted September 24, 2019 Share Posted September 24, 2019 What happens when you turn the high beams on? do the low beams go out? Do you have a wiring diagram? If so test for voltage at the at the bulbs and trace the voltage back to the fuse and find the last place that has voltage Quote Link to comment Share on other sites More sharing options...
Switta Posted September 24, 2019 Author Share Posted September 24, 2019 The low beams stay on . i have been trying to find a wiring diagram on line for the headlight system but not found anything yet . ya i think your right i will back check the system starting at the bulbs and find where it lost it's voltage . i get not click on the high beam relay . thanks for the reply . Dave . Quote Link to comment Share on other sites More sharing options...
dinocarsfast Posted September 25, 2019 Share Posted September 25, 2019 You dont get a click from the relay? Sounds like that is the problem, test the voltage at the coil side if that switches from low to high when you pull or push the stalk on the steering wheel. Also maybe get an alligator clip or flat spade connectors on both sides of a jumper wire and take the relay out and jump the contact side of the relay to see if the lights will turn on. Quote Link to comment Share on other sites More sharing options...
tyson Posted November 14, 2024 Share Posted November 14, 2024 Hi Dave did you figure this issue out, i am having the same issue but the bulbs and relay seem to be good? Help haha Quote Link to comment Share on other sites More sharing options...
tyson Posted November 15, 2024 Share Posted November 15, 2024 I am having the same issues, my high beams wont work, bulbs are fine, relay is fine. but when i turn on my high beams (as i discovered driving through the mountains this weekend) it just goes dark. Any suggestions 2012 ford transit connect Quote Link to comment Share on other sites More sharing options...
