Green/Orange Wire Drivers Side Rear Door 2013 Transit Connect XL
GN-OG
From connector C438 (inside rear door post) to connector C4247 in the door.
Rear Window Defrost Grid, Left.
It comes from fuse F178 in front, but that's switched by the Defrost Relay in the CJB.
Just pop the fuse out to disconnect the wire from the defrost relay.
The wire is GN-BU at the CJB, but it's probably buried in some wire harness.
But It goes through C237, pin 11, which is inside the panel next to your left foot.
That should be easy to find. Remove the panel, pull out the two connectors, and see which one has 12 volts on pin 11 when the defroster is on.
The problem is that it feeds both defroster grids and I can't tell where the split is. You'd have to disconnect the RH defroster in the door, which I'm guessing would be easiest.
If you don't have the camera, check to see if the connector is there anyway. It's a six-pin flat connector, coming out of the harness labelled "UAB.". Hot is pin 1, YE-VT. Signal is pin 3.
