nickh Posted November 20, 2011 Share Posted November 20, 2011 My Connect is losing about 1 litre of coolant in 40 miles, no visible signs of leak. No water in oil, cannot see/smell coolant in exhaust. Have not had a coolant test for exhaust fumes yet, so could be headgasket. I changed reservoir cap. Losses are not consistent, occasionally I don't lose so much & sometimes more. Garage looked for leaks & changes thermostat, seemed to work for firat 30 miles, but now I am losing coolant again. Quite a bit of airlocking. Sounds expensive, only had the van 6 weeks, it is an 08 with 70K miles. any ideas. Many thanks Nick Quote Link to comment Share on other sites More sharing options...
Willie Posted November 20, 2011 Share Posted November 20, 2011 My Connect is losing about 1 litre of coolant in 40 miles, no visible signs of leak. No water in oil, cannot see/smell coolant in exhaust. Have not had a coolant test for exhaust fumes yet, so could be headgasket. I changed reservoir cap. Losses are not consistent, occasionally I don't lose so much & sometimes more. Garage looked for leaks & changes thermostat, seemed to work for firat 30 miles, but now I am losing coolant again. Quite a bit of airlocking. Sounds expensive, only had the van 6 weeks, it is an 08 with 70K miles. any ideas. Many thanks Nick I think that that amount of coolant would be very obvious in the exhaust or oil. Often coolant leaks only when the engine is running. It might also evaporate when the engine becomes warm. For these reasons you may not see it on the garage floor. I'm hoping that it is something cheap and easy to repair, and I have a hunch it is. Good luck. Quote Link to comment Share on other sites More sharing options...
nickh Posted November 21, 2011 Author Share Posted November 21, 2011 I think that that amount of coolant would be very obvious in the exhaust or oil. Often coolant leaks only when the engine is running. It might also evaporate when the engine becomes warm. For these reasons you may not see it on the garage floor. I'm hoping that it is something cheap and easy to repair, and I have a hunch it is. Good luck. Cheers Willie - I will keep working on it - it's encouraging that you think it might not be the headgasket. Quote Link to comment Share on other sites More sharing options...
