Transit Connect OEM Factory Roof Rails (from a 2019)
These came off my 2019 TC. I had to remove them because I wanted to install a heavy duty Rhino Platform Rack. Actually now in hind sight... I probably could have save myself a lot of trouble and adapted the mounts to work with the factory roof rails. Live and learn.
These come standard on the Titanium package
These were removed from a 2019 Ford Transit Connect Titanium
They retail for about $1,200.00 plus tax purchased from any Ford dealership. Please call your local dealer to confirm!
Pictured is a TC with factory roof rails and one with out.
Note:
If you have a TC that has a headliner, it will have to be removed in order to install the factory roof rail. They are installed with 5 bolts on each side. You can check with your local dealer to see how much they would charge you to remove the headliner, install the rails and reassemble the headliner.
If you have a TC cargo version without a headliner, then the installation is simple. The bolt holes are already within the channels of the roof, covered by plugs.
Asking $500.00 local pick up (SF Bay Area)
or plus shipping
