Dvanham Posted March 27, 2019 Share Posted March 27, 2019 I have a 2010 Transit Connect with a check engine light on. I pulled the DTC code from the dash display “C 127”. Couldn’t find anything on the internet for that code so I took the vehicle into a shop and had them scan it. The code came up as lost communication to the steering angle sensor. The code was cleared and about 3 weeks later check engine light came on again. Checked and same code C 127 came up reading from the dash. Has anybody else ran into this issue? The sensor is almost $500 at the dealer, haven’t found any supplier aftermarket and a little reluctant to go used. Any ideas that may help to test the sensor before I spend that kind of money to find out that it is actually a wiring problem rather than the sensor itself? Quote Link to comment Share on other sites More sharing options...
