50 Day limit on key off (NON USE)
I JUST DISCOVERED THAT THE SECURITY SYSTEM ON MY 2010 T/C BLOCKED ALL ATTEMPTS TO START. IT ALL BEGAN WHEN I TRIED TO START MY T/C AFTER IT HAD SAT UNUSED FOR SOME TIME. IT BEHAVED LIKE THE BATTERY WAS LOW. I TRIED A JUMPER CABLE, NO GO. THEN I TRIED CHARGING THE BATTERY FOR SEVERAL HOURS, NO GO. VISITED THE LOCAL FORD DEALER HERE AND DESCRIBED THE SYMPTOMS: FAILURE TO CRANK, WITH A FLASHING ALARM SYSTEM LAMP ON THE INSTRUMENT PANEL. OWNERS MANUAL HINTS AT SOME SORT OF KEY PROBLEM. TRIED BOTH KEYS SAME NO GO.
TOW TRUCK CARTED IT TO DEALER. FEW HOURS LATER DEALER HASN'T A CLUE.
FORD TECHNICIAN AT A LOSS FOR SOLUTION. HE CONTACTS FACTORY FOLKS WHOM RECOMMEND HE READ A SPECIAL SERVICE BULLETIN, "OASIS SPECIAL SERVICE MESSAGE 21205"
AHA MOMENT...NOT MENTIONED ANYWHERE ELSE, THAT THE SECURITY SYSTEM ON SEVERAL FORD PRODUCTS, HAS A LIMIT TO ITS COMPUTER TIMER FOR KEEPING TRACK OF THE TIME THE KEY HAS BEEN IN THE OFF POSITION. LIKE IF YOU LET YOUR T/C SIT FOR MORE THAN 50 DAYS WITHOUT STARTING IT.
SHOULD YOU NOT START YOUR FORD PRODUCT FOR A PERIOD GREATER THAN 50 DAYS, LIKE IN MY CASE IT TURNED OUT TO BE 52 DAYS, THE COMPUTER BLOCKS ALL ATTEMPTS TO START BY ANY MEANS. THE CODES SHOW YOUR COMPUTER KAPUT.
FORTUNATELY WITHIN THE SPECIAL SERVICE MESSAGE THEY DESCRIBE THE SIMPLE SOLUTION...DISCONNECT THE NEGATIVE BATTERY CABLE FOR 30 SHORT SECONDS, AND ALL IS WELL AGAIN.
UNFORTUNATELY, THE COST OF THE TOW, THE TECHNICIANS TIME , ETC ARE CATIGORICALLY DENIED BY FOMOCO IN THE SPECIAL SERVICE MESSAGE.
IF ANYONE HAS READ ANYTHING BY FORD TO BE AWARE OF THIS ISSUE, I WOULD LIKE TO SEE IT. AS FORD TRANSIT CONNECT OWNERS/OPERATORS I BELIEVE WE SHOULD HAVE HAD SOME WARNING FROM FORD AS TO HOW MUCH TIME WE CAN LET OUR VEHICLES REMAIN IDLE. PASS THIS INFO ALONG TO OTHER FORD OWNERS, COULD SAVE THEM AN EMBARRASSING MOMENT AND NEEDLESS EXPENSES.
I Started my transit this morning realized I forgot something in the house shut it off came out seconds lateer & the vehicle would not start , checked the reset button for the fuel line, no go all the power is there but the security code does lite up on the dash, can't wait to go check it in the am this may be my problem as well!!! I'll let you knowquote name='paskenta' timestamp='1318371311' post='3399']
