aquascape Posted June 16, 2011 Share Posted June 16, 2011 On my 2007 transit connect with 105k on it, not always but sometimes after a long journey I check the coolant level when I get home and it is fine but by the next morning it is half empty. It never loses any water when in use and if definitely doesn't leak onto the floor. If drives lovely. Any ideas? Quote Link to comment Share on other sites More sharing options...
cdiesel Posted June 19, 2011 Share Posted June 19, 2011 (edited) yea, after a drive and fully hot, remove the spark plugs, and let it sit for 1.5 hour, Come back with a helper to work the ignition key to crank it over while you watch for coolent pumping out of the plug holes. PROTECT YOUR EYES!. If coolent is pumping out of the holes - proceed to removal of cylinder head. Your facing a leaking head gasket, or cracked head. report back look at your oil dip stick and inside the oil filler cap. If mochachino creamy stuff is forming? same as above. Edited June 20, 2011 by cdiesel Quote Link to comment Share on other sites More sharing options...
