ontheroad Posted June 11, 2011 Share Posted June 11, 2011 Hello, Can anyone tell me where to pass a wire from the TC engine compartment to the dashboard? I am hooking up some driving lights and need to run a switch wire to the turn signal stalk. Thanks! Jon Quote Link to comment Share on other sites More sharing options...
103west43rd Posted June 11, 2011 Share Posted June 11, 2011 On 6/11/2011 at 1:35 AM, ontheroad said: Hello, Can anyone tell me where to pass a wire from the TC engine compartment to the dashboard? I am hooking up some driving lights and need to run a switch wire to the turn signal stalk. Thanks! Jon There are two large grommets in the firewall behind and slightly above the brake pedal. If you remove them and then look under the hood and behind the battery, you can see into the interior. I ran my wiring through the grommets when I added my driving and fog lamps. Take a look at my gallery pictures to see how they turned out. Good luck. Groovey 1 Quote Link to comment Share on other sites More sharing options...
ontheroad Posted June 11, 2011 Author Share Posted June 11, 2011 On 6/11/2011 at 1:45 AM, 103west43rd said: There are two large grommets in the firewall behind and slightly above the brake pedal. If you remove them and then look under the hood and behind the battery, you can see into the interior. I ran my wiring through the grommets when I added my driving and fog lamps. Take a look at my gallery pictures to see how they turned out. Good luck. Found 'em! Thank you very much. Quote Link to comment Share on other sites More sharing options...
kndlkstms Posted November 3, 2015 Share Posted November 3, 2015 This may be a little late for you , but i found the customer access circuit wires ( 5 ) on my daughter's '12 premium wagon . The 2 "pass thru" wires and the three fused wires ( no fuses or the "battery saver relay" ) . I have a feeling that most/all transits have the wires , but fuses and the relay make the " modified vehicle wiring " package . My concern is the 3 tiny "signal" wires, they're 10 Amp fused. Maybe they're meant to signal a relay , but where to get a big hot wire ? The 2 " pass thru " would be easier / better to use since they are in the harness . Quote Link to comment Share on other sites More sharing options...
