Interior Lighting Question
kgibb
Hi folks,
I'm currently converting an 08 LWB Connect into a stealth camper and looking at lighting solutions for the cargo space where I will be cooking and sleeping.  I have a 5m coil of 12V 5050 LEDs which will work off the existing connection but will be much brighter than the existing bulbs and hopefully use less battery power (depending on how long I keep the coil obviously)
Currently the switch in the cab for the reading light controls both this and the cargo area light simultaneously and they can be set to OFF/DOORS/ON. Obviously I'd like to be able to switch the cargo space lights on independently of the cab light from the back of the van.
Is this a simple case of bypassing the cab switch and installing a switch (and in line fuse?) in the rear? If so, what is the best way of bypassing the front switch? I've included a picture of the switch in the cab with the white cable to the right supplying the cargo area light and the fixing for the light in the cargo area.
Any advice would be greatly appreciated!
Thanks
K
