T0ASTERvan Posted July 18, 2016 Share Posted July 18, 2016 (edited) Soon after the purchase of the 2015 transit Connect we opted to remove the factory scissor jack and replace it with a 2 ton floor jack. Removing the factory jack from the rear (driver side) cubbyhole.. it's never been used but don't include the factory tire iron, seeing how the tire iron has a fitted key as to lower the spare tire. I'm not sure if an allen or torque set/socket would fit in this location. Otherwise, make an offer on this scissor jack w/o the tire iron, unless I can locate the correct sized allen / torque set. Borrowed eBay Image *Must Include a small shipping fee with your offer* Image upon request Edited July 31, 2016 by T0ASTERvan Gave Scissor Jack To Kyle Quote Link to comment Share on other sites More sharing options...
DEFENDER Posted May 5, 2023 Share Posted May 5, 2023 On 7/18/2016 at 8:16 AM, T0ASTERvan said: Soon after the purchase of the 2015 transit Connect we opted to remove the factory scissor jack and replace it with a 2 ton floor jack. Removing the factory jack from the rear (driver side) cubbyhole.. it's never been used but don't include the factory tire iron, seeing how the tire iron has a fitted key as to lower the spare tire. I'm not sure if an allen or torque set/socket would fit in this location. Otherwise, make an offer on this scissor jack w/o the tire iron, unless I can locate the correct sized allen / torque set. http://i.ebayimg.com/images/g/a1kAAOSwPhdVJq8j/s-l300.jpg Borrowed eBay Image *Must Include a small shipping fee with your offer* Image upon request I have a 2020 Ford Transit Connect cargo truck, van. I use a long 13 mm nut. The type used for connecting rods (Rod Coupling Nuts). I would guess it can be found at most hardware stores that sell materials for ceilings. I could not find a 13 mm rod coupling nut, but I think a 1/2 inch will work, try with a 1/2 inch bolt, or a 13 mm bolt with a hex head, With a few nuts on the end. https://www.homedepot.com/p/Everbilt-1-2-in-13-tpi-Zinc-Rod-Coupling-Nuts-822301/204337404 $ 2.58 This way I can use a 13 mm socket and a ratchet wrench. Quote Link to comment Share on other sites More sharing options...
