rnt80 Posted June 4, 2010 Share Posted June 4, 2010 Any suggestions for a heavier duty roof rack? I'd be using the vehicle for my custom woodworking business and would need the roof rack for plywood and wood. It would need to be able to deal with 300lbs. if need be. Quote Link to comment Share on other sites More sharing options...
isellford Posted June 8, 2010 Share Posted June 8, 2010 MasterRack and Adrian both make a good commercial roof rack. Most areas have a body and equipment company that sells and installs them. Check their websites for distributors in your area. Also your dealer should be able to handle it for you. If you own a business, Ford will reimburse up to the 1st $200 of any upfit that you do. Quote Link to comment Share on other sites More sharing options...
dancingbrook Posted November 27, 2010 Share Posted November 27, 2010 MasterRack and Adrian both make a good commercial roof rack. Most areas have a body and equipment company that sells and installs them. Check their websites for distributors in your area. Also your dealer should be able to handle it for you. If you own a business, Ford will reimburse up to the 1st $200 of any upfit that you do. Please tell me how do I get this $200 upfit reimbursement? And where do I learn what is eligible?? Quote Link to comment Share on other sites More sharing options...
