Yangmoua2 Posted October 10, 2014 Share Posted October 10, 2014 Recently my vans been vibrating a lot in the first three gears as I accelerate once on the freeway I don't seem to notice it.. Was told by service advisor when I got my oil change motor mount could be the problem from the vibrations.. Is this something I can replace on my own or should I take it to the shop? And how long does it take for the shop to repair? Cost? Thank you Quote Link to comment Share on other sites More sharing options...
Eazy Posted October 14, 2014 Share Posted October 14, 2014 What year is your van? I believe the motor mounts are fairly easy to change if you're handy with a wrench and a jack. You should just need to jack the motor up, unbolt the mount (usually 4 bolts), and then put the new one on and reassemble. There are a lot of videos on youtube for the Focus, should be a similar process. Quote Link to comment Share on other sites More sharing options...
