connected Posted May 3, 2010 Share Posted May 3, 2010 hi all any teckys out there no why my trip clock will not reset 03 t200 tddi if that helps ? try the usual wiggle method no joy never had a problem before? Quote Link to comment Share on other sites More sharing options...
connected Posted May 5, 2010 Author Share Posted May 5, 2010 On 5/3/2010 at 4:06 PM, connected said: hi all any teckys out there no why my trip clock will not reset 03 t200 tddi if that helps ? try the usual wiggle method no joy never had a problem before? Quote Link to comment Share on other sites More sharing options...
connected Posted May 5, 2010 Author Share Posted May 5, 2010 update this is a problem with the clock master /the clock master is located in the main instrument cluster . this cannot be fixed but can be reset by unpluging the clucter for 20 mins but still has no manual control wounded.com Quote Link to comment Share on other sites More sharing options...
Willie Posted May 5, 2010 Share Posted May 5, 2010 I had a similar problem, but didn’t answer because I couldn’t quite remember exactly how I solved it. My TC has the cheaper radio without the CD player. The owner’s manual is incorrect about procedures to set the clock with this radio. In fact, you do not use the radio at all to set the clock in this case. It is all done with the right hand button just below the digital read-out on the instrument panel. I just messed around with this button until the time began to change. I’m sorry I do not recall the precise manipulation, I used. Quote Link to comment Share on other sites More sharing options...
