goco Posted March 17, 2014 Share Posted March 17, 2014 hello Every One My 2010 Transit Connect xlt just quit working ,and its looks like immobiliser stuck , red lock blinking on dashboard . Have try both keys and no different . Have Any One expirence with same problem. Its have 67k and any problems on the past. Thanks for respond Quote Link to comment Share on other sites More sharing options...
robertlane Posted March 21, 2014 Share Posted March 21, 2014 hello Every One My 2010 Transit Connect xlt just quit working ,and its looks like immobiliser stuck , red lock blinking on dashboard . Have try both keys and no different . Have Any One expirence with same problem. Its have 67k and any problems on the past. Thanks for respond Have you solved this issue yet? Quote Link to comment Share on other sites More sharing options...
TC2014 Posted March 31 Share Posted March 31 I realize this is an old thread but in case anyone else is looking, here's some pointers: Blinking IMMO light usually indicates a loss of the programming for the transponder chips or possibly a miscommunication between the Immobilizer Coil and the keys themselves. First, check to see you have not lost the chips from your keys. Second, try to connect a scan-tool to read codes. Some of the more advanced tools can tell you if the keys are programmed to the vehicle. Third, check fuses related to the computer and immobilizer system (make sure all your electrical connections are both tight and clean). Finally, remove the shroud cover and see if the connector for the Immobilizer Ring has become disconnected. If you don't have that advanced of a scan tool or require another key, you're best to call a vehicle locksmith and have them run a diagnostic and programming for you. Quote Link to comment Share on other sites More sharing options...
