stewarts Posted October 12, 2013 Share Posted October 12, 2013 Hi, Can anyone help me with this problem I have with my connect. Its a 200D SWB. When I put my van into reverse, the lights come on, but as soon as I take my hand off the gear stick the reverse lights go off. This problem has only just started. Thanks for anybodies advice Quote Link to comment Share on other sites More sharing options...
Willie Posted October 13, 2013 Share Posted October 13, 2013 In most standard transmissions, the back-up lights are controlled by a simple switch activated by the gear lever. Your switch is probably slightly out of position breaking contact when pressure is released on the lever. Should be easy to fix. Quote Link to comment Share on other sites More sharing options...
Bigbaddave3 Posted November 7, 2013 Share Posted November 7, 2013 Bit late i know but mines the same.. Bugger in the dark.. Quote Link to comment Share on other sites More sharing options...
