Problems with locking 2010 Transit Connect
Just the other day i started having problems with locking my TC.
If i start the vehicle and put it in drive and drive away, all the doors lock fine.
If i lock the doors with the key fob, as i usually do, all doors will look but the drivers. I have to open the drivers door, which then all the other doors unlock, manually lock the front door, close it, then use the key fob to lock all the other doors.
When i go to unlock the van, i push the unlock on the key fob and all the doors unlock but the drivers, i either have to reach around from the side door and unlock it or use the key itself.
I've tried to reprogram the key fob as shown in the manual, but to no avail.
I really don't think that the battery in the fob is weak or it shouldn't open all the other doors, correct? But i had noticed over the last few weeks that i had to get closer to the vehicle for the fob to open it.
Any suggestions folks?
