BSJBSJ Posted April 3, 2025 Share Posted April 3, 2025 Anyone know how to replace the plastic base of the front, mast antenna? (2021) https://www.fordpartsgiant.com/parts/ford-aerial-without-cable_av1z-18813-a.html?vin=&make=Ford&model=Transit Connect&year=2021&submodel=&extra1=&extra2=&filter=() Mine has cracks in it. Getting water dripping through the housing for the windshield's sensors. I thought it was from a bad glass seal. While caulking I found the cracks. Caulking didn't help... Quote Link to comment Share on other sites More sharing options...
BSJBSJ Posted April 3, 2025 Author Share Posted April 3, 2025 Hopefully it is this nut, accessed under the overhead light. Quote Link to comment Share on other sites More sharing options...
Double Nickels Posted April 3, 2025 Share Posted April 3, 2025 You will need to remove the headliner. There will be a fastener. Quote Link to comment Share on other sites More sharing options...
BSJBSJ Posted April 9, 2025 Author Share Posted April 9, 2025 (edited) Was able to access the nut via the dome light opening. The nut conveniently stayed connected to the wire which made reinstullation quite easy. Unscrewed the nut with an 8mm deepwell socket. Popped the old base off, from the outside, and clicked the new one back on. Reattached the nut from the inside. Easy... The old one was definitely leaking. Edited April 9, 2025 by BSJBSJ Quote Link to comment Share on other sites More sharing options...
